Saltar al contenido principal
  1. Turn your laptop over so the underside is facing up. Turn your laptop over so the underside is facing up.
    • Turn your laptop over so the underside is facing up.
  2. Identify the two sliding locks on either side of the battery. Simultaneously slide both locks outward to release the battery.
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Pull the battery straight out of its slot to remove it.
    • Pull the battery straight out of its slot to remove it.
  4. Locate the optical drive retaining screw on the underside of the laptop.
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Using your finger or a spudger, push the optical drive out of its compartment so you can grab it. Pull the optical drive out of its slot in the side of the laptop.
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
  7. Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  8. Using a spudger or plastic opening tool, pry off the service panel.
    • Using a spudger or plastic opening tool, pry off the service panel.
  9. Using your fingers, pull the retaining clips away from the RAM sticks. Pull the RAM sticks out of the slots. Pull the RAM sticks out of the slots.
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
  10. Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop. The service panel should already be removed.
    • Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop.
    • The service panel should already be removed.
  11. Using a Phillips #00 screwdriver, remove the five screws under the service panel. Remove the retaining clip.
    • Using a Phillips #00 screwdriver, remove the five screws under the service panel.
    • Remove the retaining clip.
  12. Using a spudger, pry the keyboard from the top panel of the laptop.
    • Using a spudger, pry the keyboard from the top panel of the laptop.
    • Make sure to pry it off all around.
  13. Disconnect the two ribbon cables connecting the keyboard to the laptop. Unplug the connector on the bottom of the laptop. Unplug the connector on the bottom of the laptop.
    • Disconnect the two ribbon cables connecting the keyboard to the laptop.
    • Unplug the connector on the bottom of the laptop.
Conclusión
Jesse Adam Ory
Miembro Desde 24/03/19
745 Reputación
7 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 194
