Introducción
If the computer is booting directly to the BIOS screen and there is enough RAM, then use this guide to replace the Hard Disk Drive.
Qué necesitas
Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
Pull off the part of the case that's now loose by the indicated tab.
Use the JIS screwdriver head to remove the 3.7mm long JIS #0 screws at the base of the hard drive.
Una persona más ha completado esta guía.
