Introducción
If you need to get to the Hard Disk Drive or need to remove the CD drive, use this guide.
Qué necesitas
Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
Pull off the part of the case that's now loose by the indicated tab.
Casi Terminas!
Conclusión
