Introducción
When your computer is making loud noises or is hot to the touch, you likely need to replace your fan. Follow this guide to do so. Prerequisites for this guide is the battery removal and keyboard removal.
Qué necesitas
Find an edge of the red strip along the edge the computer and pry it off using a spudger.
Remove the four 8 mm screws holding the two circuit boards together using a Phillips #0 screwdriver.
2 personas más completaron esta guía.
