Introducción
Use this guide to replace RAM/Memory modules in a Toshiba Portege R705-P25.
What is Random Access Memory (RAM)? Check out this iFixit page about Computer Memory to learn.
Some common reasons for this guide are replacing faulty memory modules/sticks or simply upgrading the pre-existing ones.
-Be careful on selecting new RAM modules as they may not be compatible with older laptops like this Toshiba Portege. Please refer to the Parts list to see what type of RAM would work best with this laptop or the Detailed Product Specification.
This guide instructs you how to locate the RAM access panel on the back and unscrew it. Then replace the RAM sticks. For extra help, please refer to the Service Manual (Pages 51-59).
Qué necesitas
Turn the computer over and locate the RAM access panel (bracketed with yellow lines).
Locate the head of each screw (highlighted in yellow). Using a small Phillips head screwdriver, fit the metal cross shaped point into the head of each screw.
Apply medium-light pressure to the screwdriver and rotate counter-clockwise to unscrew the RAM access panel. Do this for both screws.
Use your finger or screwdriver to remove the panel by gently lifting from the lip next to the icon indicated in red.
To insert the new RAM module, locate the appropriate RAM housing and place the module diagonally into the slot.
Next, gently push the module down towards and into the laptop until the small metal tabs acoustically snap into place.
If desired, repeat the last two steps for installing the top module.
4 personas más completaron esta guía.
