Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
  1. Use a bit driver and a Phillips #0 bit to remove the one 5 mm retaining screw. Lift the panel up and out of the way.
    • Use a bit driver and a Phillips #0 bit to remove the one 5 mm retaining screw.
    • Lift the panel up and out of the way.
  2. The RAM chip is secured by two retaining arms that run parallel with the chip. Gently pull these arms in opposite directions off of the chip. After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal. After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal.
    • The RAM chip is secured by two retaining arms that run parallel with the chip. Gently pull these arms in opposite directions off of the chip.
    • After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal.
  3. Push the replacement RAM into the original position. Reattach both securing arms onto the sides of the RAM chip.
    • Push the replacement RAM into the original position.
    • Reattach both securing arms onto the sides of the RAM chip.
  4. Place the panel back into the securing slots and let it rest in its original position. With the bit driver and Phillips #0 bit, secure the panel down with one screw.
    • Place the panel back into the securing slots and let it rest in its original position.
    • With the bit driver and Phillips #0 bit, secure the panel down with one screw.
Conclusión
Una persona más ha completado esta guía.
Mason McCaskill
Miembro Desde 18/10/13
1,000 Reputación
9 Guías creadas
Equipo
Clemson, Team 14-2, Benson Fall 2013 Miembro de Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 20
Todo El Tiempo: 368
