Saltar al contenido principal
Toshiba NB205 N330PK Keyboard Replacement
Qué necesitas
  1. Toshiba NB205 N330PK Keyboard Replacement, Power Button: paso 1, imagen 1 de 2 Toshiba NB205 N330PK Keyboard Replacement, Power Button: paso 1, imagen 2 de 2
    • Start by first removing the battery.
    • Move the first release switch to the right position.
    • Move the second release switch to the right position while pulling the battery towards the top of the netbook.
  2. Toshiba NB205 N330PK Keyboard Replacement: paso 2, imagen 1 de 2 Toshiba NB205 N330PK Keyboard Replacement: paso 2, imagen 2 de 2
    • Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
    • Using the bit driver and a Phillips #0 Bit, remove the two circled screws labelled F6. (These hold the keyboard) one screw may be under a rubber stopper
  3. Toshiba NB205 N330PK Keyboard Replacement: paso 3, imagen 1 de 2 Toshiba NB205 N330PK Keyboard Replacement: paso 3, imagen 2 de 2
    • While holding the top of the netbook, flip the netbook over.
  4. Toshiba NB205 N330PK Keyboard Replacement: paso 4, imagen 1 de 2 Toshiba NB205 N330PK Keyboard Replacement: paso 4, imagen 2 de 2
    • Carefully lift off the power bar assembly for access to the button and receiver.
  5. Toshiba NB205 N330PK Keyboard Replacement, Keyboard: paso 5, imagen 1 de 2 Toshiba NB205 N330PK Keyboard Replacement, Keyboard: paso 5, imagen 2 de 2
    • Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
  6. Toshiba NB205 N330PK Keyboard Replacement: paso 6, imagen 1 de 2 Toshiba NB205 N330PK Keyboard Replacement: paso 6, imagen 2 de 2
    • Reach under the keyboard and disconnect the electrical connection.
    • Lift the broken keyboard off.
  7. Toshiba NB205 N330PK Keyboard Replacement: paso 7, imagen 1 de 3 Toshiba NB205 N330PK Keyboard Replacement: paso 7, imagen 2 de 3 Toshiba NB205 N330PK Keyboard Replacement: paso 7, imagen 3 de 3
    • Reattach the new electrical connection into the old connection location.
    • Place the keyboard into the original location starting with the bottom first.
    • Gently press the keyboard down to secure it into its original location.
Linea de Meta
Una persona más ha completado esta guía.
Mason McCaskill
Miembro Desde 10/18/13
1,000 Reputación
9 Guías creadas
Equipo
Clemson, Team 14-2, Benson Fall 2013 Miembro de Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Miembros
27 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 834
