Saltar al contenido principal
Toshiba HD-A2 Power Button Replacement
Qué necesitas
  1. Toshiba HD-A2 Power Button Replacement, Power Button: paso 1, imagen 1 de 3 Toshiba HD-A2 Power Button Replacement, Power Button: paso 1, imagen 2 de 3 Toshiba HD-A2 Power Button Replacement, Power Button: paso 1, imagen 3 de 3
    • Using your hands, pop off the black console from each hinge surrounding the case.
    • There are a total of 7 hinges.
  2. Toshiba HD-A2 Power Button Replacement: paso 2, imagen 1 de 1
    • With the inside of the console facing up, the power button will be encased in clear plastic located on the right side of the console.
  3. Toshiba HD-A2 Power Button Replacement: paso 3, imagen 1 de 2 Toshiba HD-A2 Power Button Replacement: paso 3, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the single screw holding the power button to the console.
    • After taking out the screw, the small piece of metal underneath will come loose. Carefully place this part aside.
  4. Toshiba HD-A2 Power Button Replacement: paso 4, imagen 1 de 1
    • Using your fingers, gently pull out the power button. You can push it from the outside to help loosen it from its hinges.
Conclusión
Nouriyah Saleh
Miembro Desde 10/22/18
800 Reputación
6 Guías creadas
Equipo
UC Davis, Team S11-G1, Lore Fall 2018 Miembro de UC Davis, Team S11-G1, Lore Fall 2018
UCD-LORE-F18S11G1
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 149
