Saltar al contenido principal
Introducción
If you find that your DVD player is overheating, use this guide to remove and replace the fan.
Partes
No se especificaron partes.
  1. Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
    • Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
  2. Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver. Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
    • Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
  3. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  4. Using your hand, gently lift the black top panel and safely place it off to the side.
    • Using your hand, gently lift the black top panel and safely place it off to the side.
  5. The fan will be attached to the case, connected to the yellow circuit board.
    • The fan will be attached to the case, connected to the yellow circuit board.
  6. Remove the two 7mm Phillips head screws attaching the fan to the case of the DVD player. Remove the two 7mm Phillips head screws attaching the fan to the case of the DVD player.
    • Remove the two 7mm Phillips head screws attaching the fan to the case of the DVD player.
  7. Use your fingers to unplug the red and black wire from the yellow circuit board to completely remove the fan. Use your fingers to unplug the red and black wire from the yellow circuit board to completely remove the fan.
    • Use your fingers to unplug the red and black wire from the yellow circuit board to completely remove the fan.
Conclusión
Nouriyah Saleh
Miembro Desde 22/10/18
749 Reputación
6 Guías creadas
Equipo
UC Davis, Team S11-G1, Lore Fall 2018 Miembro de UC Davis, Team S11-G1, Lore Fall 2018
UCD-LORE-F18S11G1
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 61
