Saltar al contenido principal
Toshiba Excite 7c Battery Replacement
Qué necesitas
  1. Toshiba Excite 7c Battery Replacement, Open  Device: paso 1, imagen 1 de 2 Toshiba Excite 7c Battery Replacement, Open  Device: paso 1, imagen 2 de 2
    • To open your device use the plastic opener. Locate the seam on your device and gently separate applying pressure down all four sides.
    • The back casing will start to peel away from the screen.
    • Carefully lift and remove the back panel with tablet lying face down on table. this will reveal the back side.
  2. Toshiba Excite 7c Battery Replacement, Remove Battery: paso 2, imagen 1 de 3 Toshiba Excite 7c Battery Replacement, Remove Battery: paso 2, imagen 2 de 3 Toshiba Excite 7c Battery Replacement, Remove Battery: paso 2, imagen 3 de 3
    • Locate the battery on the back of your device.
    • Remove the battery connector using a pair of tweezers.
    • On the side of the battery peel back but do not remove the two black pieces of tape.
    • Remove just to the white line NOT completely.
    • Carefully lift the battery out of the device, and set aside.
Conclusión
3 personas más completaron esta guía.
Reyna Serrato
Miembro Desde 10/25/14
96 Reputación
5 Guías creadas
Equipo
Gateway, Team 1-2, Johnson Fall 2014 Miembro de Gateway, Team 1-2, Johnson Fall 2014
GCC-JOHNSON-F14S1G2
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 665
