Saltar al contenido principal
Toshiba Excite 7 Battery Removal
Qué necesitas
  1. Toshiba Excite 7 Battery Removal, Battery Removal: paso 1, imagen 1 de 3 Toshiba Excite 7 Battery Removal, Battery Removal: paso 1, imagen 2 de 3 Toshiba Excite 7 Battery Removal, Battery Removal: paso 1, imagen 3 de 3
    • Remove the back cover.
    • Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
    • After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
  2. Toshiba Excite 7 Battery Removal, Remove Tape: paso 2, imagen 1 de 2 Toshiba Excite 7 Battery Removal, Remove Tape: paso 2, imagen 2 de 2
    • Remove any black tape from the device.
    • Keep the tape, you will need to put it back on when you are done.
  3. Toshiba Excite 7 Battery Removal, Unplug Wires: paso 3, imagen 1 de 2 Toshiba Excite 7 Battery Removal, Unplug Wires: paso 3, imagen 2 de 2
    • Unplug the wires from the battery.
    • The battery is the black rectangle in the middle of the device. The device has two wiring harnesses attached to it, one just above the battery and one just to the right.
  4. Toshiba Excite 7 Battery Removal, remove screws: paso 4, imagen 1 de 2 Toshiba Excite 7 Battery Removal, remove screws: paso 4, imagen 2 de 2
    • Unscrew the battery from the device.
    • The device has 5 screws to remove, keep the screws.
  5. Toshiba Excite 7 Battery Removal, Unclip and remove battery: paso 5, imagen 1 de 2 Toshiba Excite 7 Battery Removal, Unclip and remove battery: paso 5, imagen 2 de 2
    • The battery has one clip you will need to remove. The clip is located at the bottom right corner of the battery just above the right speaker. The speakers and wires are not secured to the battery, they may fall off.
    • Push the clip back then lift the battery up.
Conclusión
4 personas más completaron esta guía.
osmel fermin
Miembro Desde 01/15/15
176 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-3, Tanski Winter 2015 Miembro de USF Tampa, Team 1-3, Tanski Winter 2015
USFT-TANSKI-W15S1G3
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 1,763
