Saltar al contenido principal
Toshiba Equium M70 Faulty Graphics
Qué necesitas
  1. Toshiba Equium M70 Faulty Graphics, Toshiba Equium M70 Faulty Graphics: paso 1, imagen 1 de 1
    • This is a complete top half strip down to fix (takes me less than 30 minutes)
  2. Toshiba Equium M70 Faulty Graphics: paso 2, imagen 1 de 1
    • this is the culprit, as you can see the shim can easily overheat & go concave lifting off the chip.
  3. Toshiba Equium M70 Faulty Graphics: paso 3, imagen 1 de 1
    • cut a thin piece of alloy to the same size as the existing shim, i used an old alloy door push plate(easy to cut) & is the ideal thickness
  4. Toshiba Equium M70 Faulty Graphics: paso 4, imagen 1 de 1
    • Thoroughly clean the chip with pure alcohol, then apply an even spread of good quality thermal paste(Arctic silver 5) will never let you down
  5. Toshiba Equium M70 Faulty Graphics: paso 5, imagen 1 de 1
    • THen apply more thermal paste to the top of the shim
  6. Toshiba Equium M70 Faulty Graphics: paso 6, imagen 1 de 1
    • The new alloy shim is under the existing thin shim. I've done more than 20 of these repairs & had 100% success rate I always do the same to the CPU (might as well your already in there).,
  7. Toshiba Equium M70 Faulty Graphics: paso 7, imagen 1 de 1
    • This is the CPU with the new alloy shim fitted.
Conclusión
3 personas más completaron esta guía.
Terry Sim
Miembro Desde 02/12/11
207 Reputación
1 Guía escrita
Un comentario
Pros: Very good hi-res pictures, well explained.
Cons: The disassembly instructions are missing
Nicola Nascimento - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 16
Todo El Tiempo: 2,049
