Saltar al contenido principal
Toshiba Encore WT8-A Tablet Camera Replacement
Qué necesitas
  1. Toshiba Encore WT8-A Tablet  Camera Replacement, Motherboard: paso 1, imagen 1 de 1
    • Remove the 4 – 4.5 mm screws from the motherboard assembly.
  2. Toshiba Encore WT8-A Tablet  Camera Replacement: paso 2, imagen 1 de 1
    • Remove the 2 – 3.5 mm screws from the motherboard assembly.
  3. Toshiba Encore WT8-A Tablet  Camera Replacement: paso 3, imagen 1 de 1
    • The motherboard should come free at this point.
  4. Toshiba Encore WT8-A Tablet  Camera Replacement, Camera: paso 4, imagen 1 de 1
    • Use small plastic opening tool for the following steps.
  5. Toshiba Encore WT8-A Tablet  Camera Replacement: paso 5, imagen 1 de 2 Toshiba Encore WT8-A Tablet  Camera Replacement: paso 5, imagen 2 de 2
    • Use small plastic opening tool to pry rear facing camera flat top connector from motherboard.
  6. Toshiba Encore WT8-A Tablet  Camera Replacement: paso 6, imagen 1 de 1
    • The rear facing camera should come free at this point.
  7. Toshiba Encore WT8-A Tablet  Camera Replacement: paso 7, imagen 1 de 1
    • Use small plastic opening tool to pry front facing camera flat top connector from the motherboard
  8. Toshiba Encore WT8-A Tablet  Camera Replacement: paso 8, imagen 1 de 2 Toshiba Encore WT8-A Tablet  Camera Replacement: paso 8, imagen 2 de 2
    • The front facing camera should come free at this point.
Conclusión
Melanie Mestre
Miembro Desde 09/20/16
116 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 17-4, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G4
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 693
