Saltar al contenido principal
Toshiba Encore Mini Speakers Replacement
Qué necesitas
  1. Toshiba Encore Mini Speakers Replacement, Battery: paso 1, imagen 1 de 2 Toshiba Encore Mini Speakers Replacement, Battery: paso 1, imagen 2 de 2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Speakers Replacement: paso 2, imagen 1 de 1
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Speakers Replacement: paso 3, imagen 1 de 1
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Speakers Replacement: paso 4, imagen 1 de 2 Toshiba Encore Mini Speakers Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Speakers Replacement: paso 5, imagen 1 de 1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
  6. Toshiba Encore Mini Speakers Replacement, Speakers: paso 6, imagen 1 de 1
    • Use the spudger to pull the speaker wire plug from its socket.
  7. Toshiba Encore Mini Speakers Replacement: paso 7, imagen 1 de 1
    • Carefully use the metal spudger to remove the speaker from the frame of the phone.
    • The speaker is attached with some double-sided adhesive and may be difficult to remove.
Conclusión
Khaled Alsaghayer
Miembro Desde 03/04/17
101 Reputación
1 Guía escrita
Equipo
IUPUI, Team S5-G5, Wilson Spring 2017 Miembro de IUPUI, Team S5-G5, Wilson Spring 2017
IUPUI-WILSON-S17S5G5
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 162
