Saltar al contenido principal
Toshiba Encore Mini Battery Replacement
Qué necesitas
  1. Toshiba Encore Mini Battery Replacement, Battery: paso 1, imagen 1 de 2 Toshiba Encore Mini Battery Replacement, Battery: paso 1, imagen 2 de 2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Battery Replacement: paso 2, imagen 1 de 1
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Battery Replacement: paso 3, imagen 1 de 1
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Battery Replacement: paso 4, imagen 1 de 2 Toshiba Encore Mini Battery Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Battery Replacement: paso 5, imagen 1 de 1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
Conclusión
5 personas más completaron esta guía.
Equipo
UW Tacoma, Team 1-3, Liner SU 2015 Miembro de UW Tacoma, Team 1-3, Liner SU 2015
UWT-LINER-SU15S1G3
4 Miembros
6 Guías creadas
2 comentarios
Be sure to remove any SD cards you have first.
ecw0647 - Contestar
But where do i buy the battery?
sissyhana - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 4,046
