Saltar al contenido principal
Toshiba Chromebook CB35-A3120 Speakers Replacement
Qué necesitas
  1. Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: paso 1, imagen 1 de 2 Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: paso 1, imagen 2 de 2
    • Using a Y1 screw driver head remove all ten .9mm screws from the back cover
    • Set the screws aside in preparation for reassembly
  2. Toshiba Chromebook CB35-A3120 Speakers Replacement: paso 2, imagen 1 de 2 Toshiba Chromebook CB35-A3120 Speakers Replacement: paso 2, imagen 2 de 2
    • Remove the back cover by placing a prying tool in the SD slot and popping the clips out of place.
  3. Toshiba Chromebook CB35-A3120 Speakers Replacement: paso 3, imagen 1 de 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: paso 3, imagen 2 de 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: paso 3, imagen 3 de 3
    • Unscrew the battery by using a J1 screw driver head, and place the four .7mm screws off to the side
    • Using a pry tool, pop the battery connector out of place and gently lift the battery upward.
  4. Toshiba Chromebook CB35-A3120 Speakers Replacement: paso 4, imagen 1 de 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: paso 4, imagen 2 de 3 Toshiba Chromebook CB35-A3120 Speakers Replacement: paso 4, imagen 3 de 3
    • Remove the right side speaker by popping it out of place with your finger
    • Follow the speaker wire along the clips underneath the battery until you reach the left hand speaker
  5. Toshiba Chromebook CB35-A3120 Speakers Replacement: paso 5, imagen 1 de 2 Toshiba Chromebook CB35-A3120 Speakers Replacement: paso 5, imagen 2 de 2
    • Unplug the connector wiring the speaker to the mother board.
    • Pop the speaker out of the computer, similar to the method used in the previous step.
Conclusión
2 personas más completaron esta guía.
Jayce Houghton
Miembro Desde 02/15/17
176 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 15-6, Remmell Spring 2017 Miembro de USF Tampa, Team 15-6, Remmell Spring 2017
USFT-REMMELL-S17S15G6
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 733
