Saltar al contenido principal
Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement
Qué necesitas
  1. Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement, Back Cover: paso 1, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 2, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 2, imagen 2 de 2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 3, imagen 1 de 1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 4, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 4, imagen 2 de 2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement, Battery: paso 5, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 6, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 6, imagen 2 de 2
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 7, imagen 1 de 3 Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 7, imagen 2 de 3 Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 7, imagen 3 de 3
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 8, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 8, imagen 2 de 2
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
  9. Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement, Trackpad: paso 9, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the two screws located at the top of the trackpad.
  10. Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 10, imagen 1 de 1
    • Using an opening tool, gently lift up the edge of the trackpad.
  11. Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 11, imagen 1 de 1
    • Slide the trackpad up and out to remove the part.
  12. Toshiba CB35-C3300 Chromebook 2 Trackpad Replacement: paso 12, imagen 1 de 1
    • Flip up the black tab on the trackpad to disconnect the ribbon cable connecting the trackpad to the motherboard and gently remove the ribbon cable.
    • Remove the trackpad from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 143
