Saltar al contenido principal
Toshiba CB35-C3300 Chromebook 2 SSD Replacement
Qué necesitas
  1. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: paso 1, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: paso 2, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: paso 2, imagen 2 de 2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: paso 3, imagen 1 de 1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: paso 4, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: paso 4, imagen 2 de 2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, SSD: paso 5, imagen 1 de 1
    • Remove the translucent yellow tape that connects the Wi-Fi card and the SSD.
    • Using a Phillips #1 screwdriver, remove the single screw connecting the SSD to the motherboard.
  6. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: paso 6, imagen 1 de 1
    • Gently grab the SSD and remove the card from the SSD slot on the motherboard, careful not to damage any of the connections on the motherboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 402
