Saltar al contenido principal
Toshiba CB35-C3300 Chromebook 2 Display Replacement
Qué necesitas
  1. Toshiba CB35-C3300 Chromebook 2 Display Replacement, Display: paso 1, imagen 1 de 1
    • Start by opening your Chromebook and orient the computer as shown.
  2. Toshiba CB35-C3300 Chromebook 2 Display Replacement: paso 2, imagen 1 de 1
    • Using the opening tool, start at one of the two top corners and pull the faceplate away from the display.
    • Use the opening tool to work your way all the way around the frame.
  3. Toshiba CB35-C3300 Chromebook 2 Display Replacement: paso 3, imagen 1 de 1
    • Using a Jimmy, carefully pop the bottom of the faceplate away from the display.
  4. Toshiba CB35-C3300 Chromebook 2 Display Replacement: paso 4, imagen 1 de 1
    • Remove the faceplate by pulling away from the keyboard.
  5. Toshiba CB35-C3300 Chromebook 2 Display Replacement: paso 5, imagen 1 de 1
    • Using an opening tool, start from one of the top corners of the screen and begin to pry it away from the top of the laptop.
    • Make sure that you can keep the foil on the Chromebook.
  6. Toshiba CB35-C3300 Chromebook 2 Display Replacement: paso 6, imagen 1 de 1
    • Using the Jimmy, remove the sticker holding the wire to this display.
  7. Toshiba CB35-C3300 Chromebook 2 Display Replacement: paso 7, imagen 1 de 1
    • Carefully remove the ribbon the display and remove the display from the Chromebook.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 158
