Saltar al contenido principal
Toshiba CB35-C3300 Chromebook 2 Battery Replacement
Qué necesitas
  1. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Back Cover: paso 1, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: paso 2, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: paso 2, imagen 2 de 2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: paso 3, imagen 1 de 1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: paso 4, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: paso 4, imagen 2 de 2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Battery: paso 5, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: paso 6, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: paso 6, imagen 2 de 2
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: paso 7, imagen 1 de 3 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: paso 7, imagen 2 de 3 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: paso 7, imagen 3 de 3
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: paso 8, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: paso 8, imagen 2 de 2
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
Conclusión
Una persona más ha completado esta guía.
varun kapadia
Miembro Desde 10/18/17
219 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S1-G121, Cagle Fall 2017 Miembro de USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
3 Miembros
14 Guías creadas
Un comentario
Thanks again IFIXIT!!! Repaced battery on Toshiba C35 C3300 with your HELP. Guy Rogers
Guy Rogers - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 1,215
