Saltar al contenido principal
Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement
Qué necesitas
  1. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: paso 2, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: paso 2, imagen 2 de 2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: paso 3, imagen 1 de 1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: paso 4, imagen 1 de 2 Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: paso 4, imagen 2 de 2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S1-G121, Cagle Fall 2017 Miembro de USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 384
