Saltar al contenido principal
Toshiba A1304T Mini LCD Screen Replacement
Qué necesitas
  1. Toshiba A1304T Mini LCD Screen Replacement, Front Cover: paso 1, imagen 1 de 1
    • Open the phone so that it matches the photos to the left.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
  2. Toshiba A1304T Mini LCD Screen Replacement: paso 2, imagen 1 de 2 Toshiba A1304T Mini LCD Screen Replacement: paso 2, imagen 2 de 2
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Mini LCD Screen Replacement: paso 3, imagen 1 de 2 Toshiba A1304T Mini LCD Screen Replacement: paso 3, imagen 2 de 2
    • Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
    • Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
  4. Toshiba A1304T Mini LCD Screen Replacement, Mini LCD Screen: paso 4, imagen 1 de 2 Toshiba A1304T Mini LCD Screen Replacement, Mini LCD Screen: paso 4, imagen 2 de 2
    • Using a small Phillips screwdriver, gently pry off the LCD screen from the board.
  5. Toshiba A1304T Mini LCD Screen Replacement: paso 5, imagen 1 de 2 Toshiba A1304T Mini LCD Screen Replacement: paso 5, imagen 2 de 2
    • Using the head of the screwdriver, flip up the black tab connecting the ribbon-wire.
    • Gently pull the LCD screen away from the board, the cable should come off with nearly no resistance.
Conclusión
Una persona más ha completado esta guía.
Christopher
Miembro Desde 04/22/10
90 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 16-6, Maness Spring 2010 Miembro de Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,902
