Saltar al contenido principal
Toshiba A1304T Keypad Replacement
Qué necesitas
  1. Toshiba A1304T Keypad Replacement, Back panel: paso 1, imagen 1 de 1
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. Toshiba A1304T Keypad Replacement: paso 2, imagen 1 de 1
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Keypad Replacement: paso 3, imagen 1 de 2 Toshiba A1304T Keypad Replacement: paso 3, imagen 2 de 2
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  4. Toshiba A1304T Keypad Replacement, Keypad: paso 4, imagen 1 de 3 Toshiba A1304T Keypad Replacement, Keypad: paso 4, imagen 2 de 3 Toshiba A1304T Keypad Replacement, Keypad: paso 4, imagen 3 de 3
    • Use your fingers to detach the ribbon wire located on the top of the logic board, as shown.
  5. Toshiba A1304T Keypad Replacement: paso 5, imagen 1 de 2 Toshiba A1304T Keypad Replacement: paso 5, imagen 2 de 2
    • Use a flathead screwdriver to gently pry the logic board and keypad from the device.
  6. Toshiba A1304T Keypad Replacement: paso 6, imagen 1 de 2 Toshiba A1304T Keypad Replacement: paso 6, imagen 2 de 2
    • Peel the keypad from the logic board using your thumb.
Conclusión
Christopher
Miembro Desde 04/22/10
90 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 16-6, Maness Spring 2010 Miembro de Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 1,686
