Saltar al contenido principal
Top Fin 20gal Filter Replacement
Qué necesitas
  1. Top Fin 20gal Filter Replacement, Filter cartridge: paso 1, imagen 1 de 2 Top Fin 20gal Filter Replacement, Filter cartridge: paso 1, imagen 2 de 2
    • Make sure the filter is turned off!
    • Unplug the filter.
  2. Top Fin 20gal Filter Replacement: paso 2, imagen 1 de 2 Top Fin 20gal Filter Replacement: paso 2, imagen 2 de 2
    • Remove the filter lid by pushing it up with both hands.
  3. Top Fin 20gal Filter Replacement: paso 3, imagen 1 de 2 Top Fin 20gal Filter Replacement: paso 3, imagen 2 de 2
    • Pull the old filter cartridge out of the filter.
    • Dispose of it in the garbage afterwards.
  4. Top Fin 20gal Filter Replacement: paso 4, imagen 1 de 1
    • Rinse the new filter cartridge with cold water.
    • Cold water removes dust in the filter cartridge.
  5. Top Fin 20gal Filter Replacement: paso 5, imagen 1 de 3 Top Fin 20gal Filter Replacement: paso 5, imagen 2 de 3 Top Fin 20gal Filter Replacement: paso 5, imagen 3 de 3
    • Insert the filter cartridge replacement into the filter slot.
  6. Top Fin 20gal Filter Replacement: paso 6, imagen 1 de 2 Top Fin 20gal Filter Replacement: paso 6, imagen 2 de 2
    • Pour water into the filter using a small bucket of water.
    • At least half a bucket of water is sufficient.
  7. Top Fin 20gal Filter Replacement: paso 7, imagen 1 de 2 Top Fin 20gal Filter Replacement: paso 7, imagen 2 de 2
    • Put the lid back on.
    • Ensure a click sound is made to secure the lid.
  8. Top Fin 20gal Filter Replacement: paso 8, imagen 1 de 2 Top Fin 20gal Filter Replacement: paso 8, imagen 2 de 2
    • Plug in the filter.
Conclusión
The filter should power on and water flows through the filter.
Rohme Cabacungan
Miembro Desde 09/09/21
157 Reputación
1 Guía escrita
Equipo
Un comentario
You guys are awesome and have guides out in everything. My many thanks to all the ifixit staff and reverse engineering minds.
DeCon ReCon - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 38
Ultimos 30 días: 188
Todo El Tiempo: 13,721
