Saltar al contenido principal
Toolcraft ST-50D solder station Disassembly
Qué necesitas
  1. Toolcraft ST-50D solder station Disassembly, So looks the solder station.: paso 1, imagen 1 de 1
    • I think you can disassembly other models of Toolcraft ST solder stations 50/80/100 analog or digital the same way.
  2. Toolcraft ST-50D solder station Disassembly, Put the solder station on the back.: paso 2, imagen 1 de 1
    • There are two holes with screws on the bottom side (green circles on the picture) and the 2-nd pair of screws is under the two rubbery "legs" (red circles).
  3. Toolcraft ST-50D solder station Disassembly, Unglue the two "legs"...: paso 3, imagen 1 de 1
    • ... by nails or by flat screwdriver and you will see the second pair of holes with screws.
  4. Toolcraft ST-50D solder station Disassembly, Unscrew the screws ...: paso 4, imagen 1 de 1
    • ... by Phillips #1 screwdriver and you can open the body of the solder station.
  5. Toolcraft ST-50D solder station Disassembly: paso 5, imagen 1 de 1
    • The cables connected to switch: ON is Up , from inside: 1) RED + BLUE 2) BROWN
  6. Toolcraft ST-50D solder station Disassembly: paso 6, imagen 1 de 1
    • From inside.
Conclusión
Una persona más ha completado esta guía.
Martin Kubica
Miembro Desde 05/13/16
784 Reputación
1 Guía escrita
4 comentarios
Hi! Unfortunately, I have stupidly pulled off the contact sockets of the switch when disassembling my station. But I did not notice how they were originally connected. Could you please take a look and maybe take a picture of how the contacts are connected to the switch? I thank you in advance.
omanoman - Contestar
Hi.
So I added a picture of cables connected to the switch. ON position of the switch is Up, the cables are from inside of the solder station.
Martin Kubica
Martin Kubica - Contestar
Hello Martin, really appreciate your guide but do you have a photo of the back of the board with all the connections? I took it apart but did not take note of which connector the White, Blue and Red/Black wires went to. Its not clear on the photos above, would be hugely appreciated. Thanks!
Michael Telatynski - Contestar
здравствуйте помагите найти на нее нагревательный элементяя даже не знаю какой должен быть спасибо
Павел Vor - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 30
Todo El Tiempo: 1,682
