Saltar al contenido principal
Tommy Hilfiger Quartz Watch Band Link Replacement
Qué necesitas
  1. Tommy Hilfiger Quartz Watch Band Link Replacement, Band Link: paso 1, imagen 1 de 1
    • Place the watch on your wrist and approximate the number of links to be removed.
  2. Tommy Hilfiger Quartz Watch Band Link Replacement: paso 2, imagen 1 de 1
    • Identify the arrows located directly on the links and point them downwards in the south position.
  3. Tommy Hilfiger Quartz Watch Band Link Replacement: paso 3, imagen 1 de 3 Tommy Hilfiger Quartz Watch Band Link Replacement: paso 3, imagen 2 de 3 Tommy Hilfiger Quartz Watch Band Link Replacement: paso 3, imagen 3 de 3
    • Lay and secure the wristband on the watchband holder.
  4. Tommy Hilfiger Quartz Watch Band Link Replacement: paso 4, imagen 1 de 3 Tommy Hilfiger Quartz Watch Band Link Replacement: paso 4, imagen 2 de 3 Tommy Hilfiger Quartz Watch Band Link Replacement: paso 4, imagen 3 de 3
    • Align the tip of the pin pusher on the pin.
    • Begin tapping the hammer with force to push the link pin out.
  5. Tommy Hilfiger Quartz Watch Band Link Replacement: paso 5, imagen 1 de 2 Tommy Hilfiger Quartz Watch Band Link Replacement: paso 5, imagen 2 de 2
    • Set aside the link pins and links that have been removed from the watch.
  6. Tommy Hilfiger Quartz Watch Band Link Replacement: paso 6, imagen 1 de 3 Tommy Hilfiger Quartz Watch Band Link Replacement: paso 6, imagen 2 de 3 Tommy Hilfiger Quartz Watch Band Link Replacement: paso 6, imagen 3 de 3
    • In order to add links to the wristband, ensure that the arrows are pointing upwards in the north position.
    • Secure the wristband on the watchband holder.
  7. Tommy Hilfiger Quartz Watch Band Link Replacement: paso 7, imagen 1 de 2 Tommy Hilfiger Quartz Watch Band Link Replacement: paso 7, imagen 2 de 2
    • Align the link pins to be added on the holes that connect the desired link to the wristband.
  8. Tommy Hilfiger Quartz Watch Band Link Replacement: paso 8, imagen 1 de 3 Tommy Hilfiger Quartz Watch Band Link Replacement: paso 8, imagen 2 de 3 Tommy Hilfiger Quartz Watch Band Link Replacement: paso 8, imagen 3 de 3
    • Use the hammer to gently tap the link pins into the holes until the pin is completely resting in position.
  9. Tommy Hilfiger Quartz Watch Band Link Replacement: paso 9, imagen 1 de 1
    • Finally, place the watch on your wrist to determine if the links are secure and the fitment is comfortable.
    • If adjustments need to be made, refer to step 2 for the subtraction of links and step 6 for the addition of links.
Linea de Meta
Ayush Theyyil
Miembro Desde 09/14/21
169 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 91
Todo El Tiempo: 6,049
