Saltar al contenido principal
Partes
No se especificaron partes.
  1. Peel back the sticker on the bottom of the device to reveal the two screws
    • Peel back the sticker on the bottom of the device to reveal the two screws
  2. Unscrew the two T-5 screws
    • Unscrew the two T-5 screws
  3. Shove the flat head screw driver into the edge of the device.  Pry the faceplate.
    • Shove the flat head screw driver into the edge of the device. Pry the faceplate.
  4. Release the ribbon cable.
    • Release the ribbon cable.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Identify the green motherboard.
    • Identify the green motherboard.
    • Unscrew the threes screws holding the board in place.
  7. Remove the board and battery from the back plate.
    • Remove the board and battery from the back plate.
  8. Attach the board and battery to the new back plate.
    • Attach the board and battery to the new back plate.
  9. Put the green motherboard back into the back plate and secure with the 3 screws.
    • Put the green motherboard back into the back plate and secure with the 3 screws.
  10. Snap it back together!
    • Snap it back together!
  11. Insert T-5 screws and tighten.
    • Insert T-5 screws and tighten.
  12. Replace the label to hide screws.
    • Replace the label to hide screws.
Conclusión
Mike Sollars
Miembro Desde 11/07/13
489 Reputación
3 Guías creadas
Equipo
WRI115, Team 1-1, Ruszkiewicz Spring 2013 Miembro de WRI115, Team 1-1, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G1
4 Miembros
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 10
Todo El Tiempo: 990
