1. Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
    • Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
  2. Unscrew the two T5 screws using the T5 Torx Screwdriver.
    • Unscrew the two T5 screws using the T5 Torx Screwdriver.
  3. Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
    • Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
  4. Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
    • Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
  5. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  6. Remove the screen from of the face-plate.
    • Remove the screen from of the face-plate.
  7. Insert the new screen into the face-plate.
    • Insert the new screen into the face-plate.
  8. Reattach the yellow ribbon cable to the motherboard.
    • Reattach the yellow ribbon cable to the motherboard.
  9. Using two hands, hold both ends of the device and snap the two plates together.
    • Using two hands, hold both ends of the device and snap the two plates together.
  10. Re-insert the two T5 screws and tighten.
    • Re-insert the two T5 screws and tighten.
  11. Re-apply the label edges back down to cover the screws.
    • Re-apply the label edges back down to cover the screws.
Conclusión
2 personas más completaron esta guía.
Mike Sollars
Miembro Desde 11/07/13
471 Reputación
3 Guías creadas
Equipo
WRI115, Team 1-1, Ruszkiewicz Spring 2013 Miembro de WRI115, Team 1-1, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G1
4 Miembros
3 Guías creadas
Hi! Thanks for doing this. How do I release the yellow cable from the board?
Shaun B - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 1,383
