Introducción
The motherboard is a large and central part to the GPS, with most components either connected or interfaced with it. Since this must be removed or dislodged in order to reach other interior components of the device, this guide will show how to remove it properly.
Qué necesitas
Position the device so that the underside is facing up.
Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
Firmly grab the EasyPort Mount and remove it.
Wedge a spudger between the white plastic latch and the black connection port, disconnecting the gold ribbon cable.
Slide the gold ribbon cable out of the port.
Una persona más ha completado esta guía.
