Introducción
If the screen appears undamaged on the outside, but the screen is still unresponsive to charging or pressing the buttons, then the screen may need to be replaced. Use this guide to learn how to replace the screen.
Qué necesitas
First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
Using the pointed end of the black Spudger tool, gently pry the motherboard away from the screen.
Once you have the motherboard partially pried off, use your fingers to gently pop it out of the clear, plastic clips holding it in place.
Continue to pull the motherboard away from the screen to fully expose the white backing of the screen.
Once the white backing of the screen is exposed, carefully flip the two pieces, the motherboard and the screen, over while they are still connected.
Look for the small metal piece attached to the motherboard that is wrapped around the front of the screen.
Gently slide the screen under and back to free it from the metal piece.
2 personas más completaron esta guía.
8 comentarios
Who sells the replacement screens? I can’t find them anywhere online. Do I need to contact TomTom directly?
This article is useless unless you know where to buy the replacement screen!!!!
this tutorial is without function because there is no sale of replacement screens. unfortunately
