Introducción
This guide shows you how to replace the outer casing of the watch. If you have an outer cracked screen, main button, or case, then this is the guide you need.
Qué necesitas
First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
Herramienta utilizada en este paso:Tweezers$4.99
Now lift the smaller square of copper off the Front Panel. Use the bent, metal precision tweezers and slide it under the smaller square of copper lining then gently lift it up.
You are finished when all parts have been removed to leave just the front casing by itself. To reassemble your device, follow these instructions in reverse order.
2 personas más completaron esta guía.
9Guía Comentarios
Great explaination, though you mention you don't replacement parts...? Can you share a link where you found the new front cover assembly?
Hello if the control button is tight can the button be removed and cleaned underneath
Imran
