Introducción
This guide shows how to remove and replace the back panel of your watch. It will show up in most of the other guides as well. See the other specific guides for more information on the part of the watch you are wanting to replace.
Qué necesitas
First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
This step is complete once the back and front panels are separated from each other. To reassemble your device, follow these instructions in reverse order.
