Saltar al contenido principal
TomTom ONE Screen Replacement
Qué necesitas
  1. TomTom ONE Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Screen Replacement: paso 2, imagen 1 de 2 TomTom ONE Screen Replacement: paso 2, imagen 2 de 2
    • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Screen Replacement: paso 3, imagen 1 de 1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Screen Replacement: paso 4, imagen 1 de 1
    • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  5. TomTom ONE Screen Replacement: paso 5, imagen 1 de 1
    • Next, you must remove the motherboard from the front screen.
    • Use a Torx T-7 screwdriver to unscrew the two screws.
  6. TomTom ONE Screen Replacement: paso 6, imagen 1 de 2 TomTom ONE Screen Replacement: paso 6, imagen 2 de 2
    • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
    • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  7. TomTom ONE Screen Replacement: paso 7, imagen 1 de 1
    • Once separated, use the spudger to pry around the edges of the outer casing.
  8. TomTom ONE Screen Replacement: paso 8, imagen 1 de 2 TomTom ONE Screen Replacement: paso 8, imagen 2 de 2
    • Apply pressure with thumbs to remove screen from inner casing.
    • The screen and front cover are now disconnected.
Linea de Meta
2 personas más completaron esta guía.
Alex Cauvy
Miembro Desde 04/18/10
41 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 7-7, Maness Spring 2010 Miembro de Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 9
Todo El Tiempo: 9,808
