Saltar al contenido principal
Introducción
The Tomtom Go Blue&Me is specific to certain models of Fiat, Alfa Romeo, Lancia, Jeep and Chrysler. This model is basically a Tomtom, with a "custom" boot screen showing the brand of the car it is connected to. The pedestal/stand that connects it to the car, is only the power supply. For the data connection, Bluetooth is used.
  1. Use a flat head screwdriver or plastic spatula to remove the bezels from the side of the screen. Now the torx screws are visible
    • Use a flat head screwdriver or plastic spatula to remove the bezels from the side of the screen.
    • Now the torx screws are visible
  2. When the screws are out, the screen is separated from the back of the housing. the screen is still connected with a flat cable and a power cable
    • When the screws are out, the screen is separated from the back of the housing.
    • the screen is still connected with a flat cable and a power cable
    • The power cable should be pulled first
    • The flat cable can be disconnected by lifting up the black part of the connector.
  3. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  4. Next, the main board should be disconnected from the battery and from the loud speaker
    • Next, the main board should be disconnected from the battery
    • and from the loud speaker
  5. You can now unscrew the mainboard You can now unscrew the mainboard
    • You can now unscrew the mainboard
  6. When you now lift out the mainboard, you have access to the battery and loudspeaker.
    • When you now lift out the mainboard, you have access to the battery and loudspeaker.
    • The battery is glued in. you need to heat it up to get it out.
  7. This little piece of plastic was my reason for opening it up. The longer leg was broken. I glued it with superglue and put it back. so far this seams feasible Please note the broken bits in the holes at the end of the legs: you can not actually take this out without breaking it! so be ware!
    • This little piece of plastic was my reason for opening it up. The longer leg was broken. I glued it with superglue and put it back. so far this seams feasible
    • Please note the broken bits in the holes at the end of the legs: you can not actually take this out without breaking it! so be ware!
Conclusión
hjheins
Miembro Desde 28/01/15
133 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 9
Todo El Tiempo: 70
