Saltar al contenido principal
TomTom GO Live 1535M Speaker Replacement
Qué necesitas
  1. TomTom GO Live 1535M Speaker Replacement, Motherboard: paso 1, imagen 1 de 1
    • Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
    • It may be easier to start at the corners.
  2. TomTom GO Live 1535M Speaker Replacement: paso 2, imagen 1 de 2 TomTom GO Live 1535M Speaker Replacement: paso 2, imagen 2 de 2
    • Carefully remove the reset button cable (located on the left) and the ribbon cable.
    • Remove the screen and set it aside.
  3. TomTom GO Live 1535M Speaker Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the logic board cables.
    • We highly advice that a pair of tweezers are used for this step to ensure no part is damaged.
  4. TomTom GO Live 1535M Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the 3.6mm screws with a Phillips Screwdriver.
    • After removing the screws simply lift the logic board from the base.
  5. TomTom GO Live 1535M Speaker Replacement, Speaker: paso 5, imagen 1 de 1
    • Simply lift the speaker up and out of the base to replace it.
Conclusión
Mathias Sagide
Miembro Desde 01/20/15
618 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 19-4, Blackwell Spring 2014 Miembro de USF Tampa, Team 19-4, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G4
1 Miembro
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 251
