Saltar al contenido principal
TomTom GO Live 1535M Reset Button Activation
Qué necesitas
  1. TomTom GO Live 1535M Reset Button Activation, Reset Button: paso 1, imagen 1 de 1
    • The reset button is located at the top of the device, close to the charging port. It is a small hole that is .78 mm wide.
    • Insert one end of the paper clip into the small power button hole and press down gently until you hear a "click" sound.
    • Hold paper clip in power button hole for 15 seconds.
    • The device should power on by itself with its factory default settings in place once done. If you do not see the screen power on, go back to step 1 and try repowering again.
Conclusión
Mathias Sagide
Miembro Desde 01/20/15
618 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 19-4, Blackwell Spring 2014 Miembro de USF Tampa, Team 19-4, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G4
1 Miembro
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 31
Todo El Tiempo: 3,379
