Introducción
The gasket that sits between a toilet tank and toilet bowl can deteriorate over time. When this gasket breaks down, water from the toilet tank can leak out of the toilet.
Qué necesitas
Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
Push down the flush lever.
Hold the lever down until water stops draining from the tank.
Squeeze open the spring clasp that connects the pull chain to the tank lever.
Disconnect the spring clasp from the tank lever.
Place a bucket under the supply tube to catch any dripping water.
Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
Using a socket wrench to hold the nuts, unscrew the two tank bolts with a screwdriver.
Remove the tank to bowl gasket from the opening at the top of the toilet bowl.
Use a paper towel to wipe away any residue left from the old gasket.
3 personas más completaron esta guía.
