Saltar al contenido principal
Toilet Seat Replacement
Qué necesitas
  1. Toilet Seat Replacement, Toilet Seat: paso 1, imagen 1 de 1
    • Measure the size of your toilet bowl to know what size seat to purchase.
  2. Toilet Seat Replacement: paso 2, imagen 1 de 2 Toilet Seat Replacement: paso 2, imagen 2 de 2
    • Twist the tops of the hinges of the currently installed toilet seat and pull toilet seat off to expose the screws.
  3. Toilet Seat Replacement: paso 3, imagen 1 de 3 Toilet Seat Replacement: paso 3, imagen 2 de 3 Toilet Seat Replacement: paso 3, imagen 3 de 3
    • Unscrew the screws to detach the seat.
    • If the screw is not loosening but is spinning as if it were, then hold the back plastic nut so that it can unscrew from the nut.
    • Clean the newly exposed area. This opportunity will not present itself again anytime soon so take advantage of it.
  4. Toilet Seat Replacement: paso 4, imagen 1 de 2 Toilet Seat Replacement: paso 4, imagen 2 de 2
    • Insert new special 20mm screws that are provided with the purchase of the toilet seat in the holes and tighten them.
  5. Toilet Seat Replacement: paso 5, imagen 1 de 1
    • Then re install the toilet seat by fitting the heads of the screws in the holes on the hinges of the seat.
  6. Toilet Seat Replacement: paso 6, imagen 1 de 1
    • Close caps by twisting them in the opposite direction that you did to take off the seat.
Conclusión
To re-install your previous seat, follow these instructions in reverse order.
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 24-5, Green Winter 2015 Miembro de Cal Poly, Team 24-5, Green Winter 2015
CPSU-GREEN-W15S24G5
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 1,808
