Saltar al contenido principal
Tivax MiTraveler 10Q-8 Speaker Replacement
Qué necesitas
  1. Tivax MiTraveler 10Q-8 Speaker Replacement, Rear Case: paso 1, imagen 1 de 2 Tivax MiTraveler 10Q-8 Speaker Replacement, Rear Case: paso 1, imagen 2 de 2
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Speaker Replacement: paso 2, imagen 1 de 1
    • Locate a Phillips 2.88mm screw at the charging port.
  3. Tivax MiTraveler 10Q-8 Speaker Replacement: paso 3, imagen 1 de 1
    • Use a PH000 Philips head screwdriver to remove screw.
    • Remember lefty loosey, righty tighty
  4. Tivax MiTraveler 10Q-8 Speaker Replacement: paso 4, imagen 1 de 1
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  5. Tivax MiTraveler 10Q-8 Speaker Replacement: paso 5, imagen 1 de 2 Tivax MiTraveler 10Q-8 Speaker Replacement: paso 5, imagen 2 de 2
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  6. Tivax MiTraveler 10Q-8 Speaker Replacement: paso 6, imagen 1 de 2 Tivax MiTraveler 10Q-8 Speaker Replacement: paso 6, imagen 2 de 2
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  7. Tivax MiTraveler 10Q-8 Speaker Replacement, Battery: paso 7, imagen 1 de 1
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  8. Tivax MiTraveler 10Q-8 Speaker Replacement: paso 8, imagen 1 de 1
    • Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
    • Review how to solder here.
  9. Tivax MiTraveler 10Q-8 Speaker Replacement: paso 9, imagen 1 de 2 Tivax MiTraveler 10Q-8 Speaker Replacement: paso 9, imagen 2 de 2
    • Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  10. Tivax MiTraveler 10Q-8 Speaker Replacement: paso 10, imagen 1 de 3 Tivax MiTraveler 10Q-8 Speaker Replacement: paso 10, imagen 2 de 3 Tivax MiTraveler 10Q-8 Speaker Replacement: paso 10, imagen 3 de 3
    • Once both wires have been desoldered, remove the battery from the device.
  11. Tivax MiTraveler 10Q-8 Speaker Replacement, Speaker: paso 11, imagen 1 de 1
    • With the face of the device down, locate the speaker in the upper right corner. The black oval shaped object.
    • Make sure Battery has been removed.
  12. Tivax MiTraveler 10Q-8 Speaker Replacement: paso 12, imagen 1 de 2 Tivax MiTraveler 10Q-8 Speaker Replacement: paso 12, imagen 2 de 2
    • A Phillips 3.88 mm screw holds the speaker in place.
    • Use a PH000 screwdriver to remove the screw.
  13. Tivax MiTraveler 10Q-8 Speaker Replacement: paso 13, imagen 1 de 2 Tivax MiTraveler 10Q-8 Speaker Replacement: paso 13, imagen 2 de 2
    • The speaker will be connected to two wires; one black and one red. Both run to the motherboard.
    • The wires will need to be soldered off the motherboard.
    • Locate where both wires are soldered to the motherboard.
    • Review How to Solder Here
  14. Tivax MiTraveler 10Q-8 Speaker Replacement: paso 14, imagen 1 de 2 Tivax MiTraveler 10Q-8 Speaker Replacement: paso 14, imagen 2 de 2
    • Work the iron where the red wire is soldered
    • The wire will release from the motherboard.
  15. Tivax MiTraveler 10Q-8 Speaker Replacement: paso 15, imagen 1 de 3 Tivax MiTraveler 10Q-8 Speaker Replacement: paso 15, imagen 2 de 3 Tivax MiTraveler 10Q-8 Speaker Replacement: paso 15, imagen 3 de 3
    • Work the iron where the black wire is soldered.
    • The black wire will release from the motherboard.
    • After both wires have been soldered off, the speaker will release from the device.
Conclusión
Krista
Miembro Desde 03/11/15
131 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 100
