Saltar al contenido principal
Tivax MiTraveler 10Q-8 Battery Replacement
Qué necesitas
  1. Tivax MiTraveler 10Q-8 Battery Replacement, Rear Case: paso 1, imagen 1 de 2 Tivax MiTraveler 10Q-8 Battery Replacement, Rear Case: paso 1, imagen 2 de 2
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Battery Replacement: paso 2, imagen 1 de 1
    • Locate a Phillips 2.88mm screw at the charging port.
  3. Tivax MiTraveler 10Q-8 Battery Replacement: paso 3, imagen 1 de 1
    • Use a PH000 Philips head screwdriver to remove screw.
    • Remember lefty loosey, righty tighty
  4. Tivax MiTraveler 10Q-8 Battery Replacement: paso 4, imagen 1 de 1
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  5. Tivax MiTraveler 10Q-8 Battery Replacement: paso 5, imagen 1 de 2 Tivax MiTraveler 10Q-8 Battery Replacement: paso 5, imagen 2 de 2
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  6. Tivax MiTraveler 10Q-8 Battery Replacement: paso 6, imagen 1 de 2 Tivax MiTraveler 10Q-8 Battery Replacement: paso 6, imagen 2 de 2
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  7. Tivax MiTraveler 10Q-8 Battery Replacement, Battery: paso 7, imagen 1 de 1
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  8. Tivax MiTraveler 10Q-8 Battery Replacement: paso 8, imagen 1 de 1
    • Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
    • Review how to solder here.
  9. Tivax MiTraveler 10Q-8 Battery Replacement: paso 9, imagen 1 de 2 Tivax MiTraveler 10Q-8 Battery Replacement: paso 9, imagen 2 de 2
    • Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  10. Tivax MiTraveler 10Q-8 Battery Replacement: paso 10, imagen 1 de 3 Tivax MiTraveler 10Q-8 Battery Replacement: paso 10, imagen 2 de 3 Tivax MiTraveler 10Q-8 Battery Replacement: paso 10, imagen 3 de 3
    • Once both wires have been desoldered, remove the battery from the device.
Conclusión
Maria
Miembro Desde 03/16/15
210 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 833
