Saltar al contenido principal
Tineco FLOOR ONE S3 Breeze Motherboard Replacement
Qué necesitas
  1. Tineco FLOOR ONE S3 Breeze Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Tineco FLOOR ONE S3 Breeze Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Remove six 10.6 mm screws from the back of the vacuum with a Phillips #1 screwdriver.
    • Remove the entire back piece.
  2. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove four 10.6 mm screws from the remaining white back piece with a Phillips #1 screwdriver.
  3. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: paso 3, imagen 1 de 3 Tineco FLOOR ONE S3 Breeze Motherboard Replacement: paso 3, imagen 2 de 3 Tineco FLOOR ONE S3 Breeze Motherboard Replacement: paso 3, imagen 3 de 3
    • Pry open and remove the black ring at the top of the vacuum using by using an opening tool.
    • Remove four 10.6 mm screws located underneath the previously pried ring using a Phillips #1 screwdriver.
    • Remove the top circular piece from the body of the vacuum.
  4. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the white back piece of the vacuum.
  5. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: paso 5, imagen 1 de 2 Tineco FLOOR ONE S3 Breeze Motherboard Replacement: paso 5, imagen 2 de 2
    • Unplug the wires of the battery by carefully pulling them up from the motherboard.
    • Slide the battery out of its slot and replace it with the new battery.
    • The connection may be difficult to remove. Be careful not to rip the entire connector from the motherboard.
  6. Tineco FLOOR ONE S3 Breeze Motherboard Replacement, Motherboard: paso 6, imagen 1 de 1
    • Carefully remove all the wire connections from the motherboard.
    • Take note of where and how the wires were connected, so they can be rewired to the new motherboard.
  7. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: paso 7, imagen 1 de 2 Tineco FLOOR ONE S3 Breeze Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the four 10.6 mm screws holding the motherboard using a Phillips #1 screwdriver.
    • Carefully remove the motherboard from the vacuum.
Conclusión
Dawoud Daoud
Miembro Desde 02/14/24
199 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 32
Todo El Tiempo: 90
