Saltar al contenido principal
Timex W-10 Children's Watch Battery Replacement
Qué necesitas
  1. Timex W-10 Children's Watch Battery Replacement, Battery: paso 1, imagen 1 de 3 Timex W-10 Children's Watch Battery Replacement, Battery: paso 1, imagen 2 de 3 Timex W-10 Children's Watch Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Pull on the watch strap through the top of the strap buckle to unlock the strap.
  2. Timex W-10 Children's Watch Battery Replacement: paso 2, imagen 1 de 2 Timex W-10 Children's Watch Battery Replacement: paso 2, imagen 2 de 2
    • Once the strap has been unlocked, hold onto the strap buckle and pull away from the watch to completely remove the band.
  3. Timex W-10 Children's Watch Battery Replacement: paso 3, imagen 1 de 2 Timex W-10 Children's Watch Battery Replacement: paso 3, imagen 2 de 2
    • Use the PH00 screwdriver to remove the four screws from each corner of the rear metal cover.
  4. Timex W-10 Children's Watch Battery Replacement: paso 4, imagen 1 de 2 Timex W-10 Children's Watch Battery Replacement: paso 4, imagen 2 de 2
    • Gently remove the back plate to expose the battery.
  5. Timex W-10 Children's Watch Battery Replacement: paso 5, imagen 1 de 2 Timex W-10 Children's Watch Battery Replacement: paso 5, imagen 2 de 2
    • The battery spring will propel the battery upward as soon as the base cover is removed. Be sure to place the battery in a safe spot.
Conclusión
Una persona más ha completado esta guía.
2 comentarios
I'm looking for an adult Timex watch battery replacement that has a metal watch band.
Daniel Melendrez - Contestar
Daniel Melendrez - June 12
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 79
Todo El Tiempo: 8,094
