Saltar al contenido principal
Timex T132 "iMac" Alarm Clock Battery Replacement
Qué necesitas
  1. Timex T132 "iMac" Alarm Clock Battery Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent any injury, unplug the power cord from the outlet so the device is powered off.
    • Hold the clock so it is upside down. You should be able to view its caution labels.
    • Wedge the small tip plastic opening tool between the battery cover and the edge of its slot.
    • Firmly push against the battery cover (away from its outer edge) until it slides off of the base clock.
  2. Timex T132 "iMac" Alarm Clock Battery Replacement: paso 2, imagen 1 de 3 Timex T132 "iMac" Alarm Clock Battery Replacement: paso 2, imagen 2 de 3 Timex T132 "iMac" Alarm Clock Battery Replacement: paso 2, imagen 3 de 3
    • Rotate the device so the clock's display is facing away from you.
    • Use the flat end of the spudger to pry out the battery.
    • Once fully lifted, grab the end of the battery and pull out the rest of the battery.
    • Do not remove the battery all the way because it is still connected. Doing so may result in damaging the power wires.
  3. Timex T132 "iMac" Alarm Clock Battery Replacement: paso 3, imagen 1 de 1
    • Place the clock upside down on a flat surface.
    • Because the device is irregularly shaped, you may have to manually or externally balance it.
    • Grab the blue connector covering tab near the power wires and peel the snap connector off the battery terminals to disconnect it.
    • Do not pull out the snap connector and its wires because it is still connected to the device. Doing so may result in damaging the power wires.
    • Remove the battery.
Conclusión
Tyler Price
Miembro Desde 04/07/14
1,008 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 6-2, Forte Spring 2014 Miembro de Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 265
