Introducción
Use this guide to replace the dead battery on your Timex T132 "iMac" alarm clock.
Qué necesitas
Hold the clock so it is upside down. You should be able to view its caution labels.
Wedge the small tip plastic opening tool between the battery cover and the edge of its slot.
Firmly push against the battery cover (away from its outer edge) until it slides off of the base clock.
Casi Terminas!
Conclusión
