Partes
  1. Here are the tools you will need:
    • Here are the tools you will need:
      • New roller handle set
      • Screwdriver
      • 4mm Allen wrench
  2. Open luggage and unzip backing, exposing back of roller. Using an Allen wrench, unscrew all 10 screws along the bottom plate and remove plastic coverings
    • Open luggage and unzip backing, exposing back of roller. Using an Allen wrench, unscrew all 10 screws along the bottom plate and remove plastic coverings
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Turn luggage over and using Allen wrench, unscrew all 8 bolts on the back of luggage handle assembly. Remove handle frame from luggage body
    • Turn luggage over and using Allen wrench, unscrew all 8 bolts on the back of luggage handle assembly. Remove handle frame from luggage body
    • Put the new roller handle set in place. Repeat steps 2 and 3 in the opposite order.
    • You're finished!
Linea de Meta
Emilee
Miembro Desde 13/03/14
1,341 Reputación
9 Guías creadas
Excuse me, but there's nothing in these instructions about removing the wheels from the old assembly and installing them on the new one? Can someone please supply those instructions so that I can complete this assembly? Thanks much!
robin - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 7
Últimos 30 Días: 38
Todo El Tiempo: 2,441
