1. Before beginning your repair, contact repairs@timbuk2.com to obtain a replacement tuck clip. Before beginning your repair, contact repairs@timbuk2.com to obtain a replacement tuck clip.
    • Before beginning your repair, contact repairs@timbuk2.com to obtain a replacement tuck clip.
  2. Using wire cutters or heavy duty scissors, break off old tuck clip and remove from fabric.
    • Using wire cutters or heavy duty scissors, break off old tuck clip and remove from fabric.
    • Insert scissors in the space between the strap and the buckle's first loop and cut through.
    • Next, insert scissors in second loop between the strap and the buckle's second loop and cut through. (It is easier to cut on the inside edges of the loops than to cut the loops in the center)
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Take Strap and fold in half to make a loop shape
    • Take Strap and fold in half to make a loop shape
  5. Insert one side of the loop in the middle section of the clip Hook the loop on one of the middle pegs Take pliers and pull up the loop that is around the peg
    • Insert one side of the loop in the middle section of the clip
    • Hook the loop on one of the middle pegs
    • Take pliers and pull up the loop that is around the peg
  6. Using the pliers, grab the other side of loop and pull it over the other middle peg Pull strap down and DONE!
    • Using the pliers, grab the other side of loop and pull it over the other middle peg
    • Pull strap down and DONE!
Conclusión
Pull strap through clip, tdown and DONE!
Una persona más ha completado esta guía.
Timbuk2
Miembro Desde 12/11/13
583 Reputación
3 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 8
Últimos 30 Días: 30
Todo El Tiempo: 626
