Saltar al contenido principal
TiVo Series 2 TCD540080 Hard Drive Replacement
Qué necesitas
  1. TiVo Series 2 TCD540080 Hard Drive Replacement, Removal of TiVo Series 2 TCD540080 Case: paso 1, imagen 1 de 1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Hard Drive Replacement: paso 3, imagen 1 de 2 TiVo Series 2 TCD540080 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Disconnect the power to the hard drive.
  5. TiVo Series 2 TCD540080 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Grab the hard drive data cable from both sides of the connector and unplug it from the hard drive.
    • Use extreme caution when unplugging connector and do not disconnect the data cable by pulling on the cable itself.
  6. TiVo Series 2 TCD540080 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Unscrew the two screws on the case of the hard drive with a T10 screwdriver.
    • Pull the hard drive up and out of the TiVo unit.
  7. TiVo Series 2 TCD540080 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Unscrew the four screws, shown in the picture, with a T-10 screwdriver.
    • Remove the hard drive from the case.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 33-79, Johann Spring 2010 Miembro de Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 7,681
