Saltar al contenido principal
TiVo Series 2 TCD540080 Cooling Fan Replacement
Qué necesitas
  1. TiVo Series 2 TCD540080 Cooling Fan Replacement, Removal of TiVo Series 2 TCD540080 Case: paso 1, imagen 1 de 1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Cooling Fan Replacement: paso 2, imagen 1 de 1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Cooling Fan Replacement: paso 3, imagen 1 de 2 TiVo Series 2 TCD540080 Cooling Fan Replacement: paso 3, imagen 2 de 2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Cooling Fan Replacement, Cooling Fan: paso 4, imagen 1 de 1
    • The fan is held in by four T15 screws on the rear of the device.
  5. TiVo Series 2 TCD540080 Cooling Fan Replacement: paso 5, imagen 1 de 2 TiVo Series 2 TCD540080 Cooling Fan Replacement: paso 5, imagen 2 de 2
    • Take the wound red and black wires coming from the fan and follow them back to the logic board.
    • Unplug the connector from the motherboard.
  6. TiVo Series 2 TCD540080 Cooling Fan Replacement: paso 6, imagen 1 de 2 TiVo Series 2 TCD540080 Cooling Fan Replacement: paso 6, imagen 2 de 2
    • Pull the fan towards the front and out of the TiVo unit.
Conclusión
Equipo
Cal Poly, Team 33-79, Johann Spring 2010 Miembro de Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 6
Todo El Tiempo: 5,243
