Saltar al contenido principal
TiVo Series 2 TCD24008A Power Supply Replacement
Qué necesitas
  1. TiVo Series 2 TCD24008A Power Supply Replacement, Cover: paso 1, imagen 1 de 1
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Power Supply Replacement: paso 2, imagen 1 de 1
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Power Supply Replacement: paso 3, imagen 1 de 1
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Power Supply Replacement, Power Supply: paso 4, imagen 1 de 1
    • Locate the power supply.
  5. TiVo Series 2 TCD24008A Power Supply Replacement: paso 5, imagen 1 de 1
    • Remove the belt connecting the power supply to the motherboard by pulling it out.
  6. TiVo Series 2 TCD24008A Power Supply Replacement: paso 6, imagen 1 de 1
    • Remove the red, yellow, and black cable connecting the power supply to the hard drive.
  7. TiVo Series 2 TCD24008A Power Supply Replacement: paso 7, imagen 1 de 1
    • Remove the two 0.31 inch T-9 screws from the power supply.
  8. TiVo Series 2 TCD24008A Power Supply Replacement: paso 8, imagen 1 de 2 TiVo Series 2 TCD24008A Power Supply Replacement: paso 8, imagen 2 de 2
    • Pinch the plastic plugs and lift the power supply up to detach from plugs.
    • All 4 plugs must be detached to remove power supply.
Conclusión
Phil Jones
Miembro Desde 10/11/11
41 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 5-33, Amido Fall 2011 Miembro de Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,196
