Introducción
The power supply allows for the TiVo components to work. In the situation that it needs to be replaced, this guide will walk you through the installation of the power supply
Partes
No se requieren partes.
  1. Unscrew the five 0.31 inch T-9 screws on the back cover.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. Slide the cover towards the back until it is no longer under the front cover.
    • Slide the cover towards the back until it is no longer under the front cover.
  3. Lift the cover up and off the device.
    • Lift the cover up and off the device.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Locate the power supply.
    • Locate the power supply.
  6. Remove the belt connecting the power supply to the motherboard by pulling it out.
    • Remove the belt connecting the power supply to the motherboard by pulling it out.
  7. Remove the red, yellow, and black cable connecting the power supply to the hard drive.
    • Remove the red, yellow, and black cable connecting the power supply to the hard drive.
  8. Remove the two 0.31 inch T-9 screws from the power supply.
    • Remove the two 0.31 inch T-9 screws from the power supply.
  9. Pinch the plastic plugs and lift the power supply up to detach from plugs. All 4 plugs must be detached to remove power supply.
    • Pinch the plastic plugs and lift the power supply up to detach from plugs.
    • All 4 plugs must be detached to remove power supply.
Conclusión
Phil Jones
Miembro Desde 11/10/11
41 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 5-33, Amido Fall 2011 Miembro de Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,059
